FIXED GDF570SSJ0SS GE Dishwasher - Door latch, control board or other?
R&A
Pittsburgh
GDF570SSJ0SS
Hello,
Can someone please walk us through how to check the control board and interpret what we’re seeing?
We just ordered our second replacement door latch, assuming that was the problem yet again (we replaced the first in August), but after reading some of the threads on here, it seems that something else could possibly be the culprit.
We went to startup the dishwasher tonight and the cycle was quickly interrupted by 3 quick beeps. The door is closed but the cycle will not continue.
Thank you in advance!
Check your main control board STATUS LED, Tell us how many times its flashing in a row, or if its STEADY ON or STEADY OFF.
--->Here's the main control board for your model: WD21X24901 Machine Control
To view the STATUS LED, remove the lower access panel of your dishwasher. You DO NOT have remove the control board from its metal casing when you view the STATUS LED.
When you have that panel lowered down turn the breaker back ON to your dishwasher. When viewing it leave all the electrical connectors to it plugged in.
R&A
Pittsburgh
Thank you, Jake. We do not see any sort of light on the control board. I guess that is what you mean by “STEADY OFF?” Does that indicate that the control board is the issue?
Yes, STEADY OFF indicates the control board is the culprit.
--->Here's the main control board for your model you can order: WD21X24901 Machine Control
Glad to help, yes let us know.:)
R&A
Pittsburgh
Jake, just wanted to let you know that the control board replacement fixed the problem. We can’t thank you enough for the help!
Excellent @R&A glad to hear the new control board fixed it.(y)
