GDF570SSJ2SS Random Beeps, No Power
seanberlin
California, USA
GDF570SSJ2SS
I've been having this issue for a while. The dishwasher will randomly beep throughout the day, and if I don't use it frequently enough (every 2-3 days), it'll go dead. I'll have to reset the breaker a few times to get it to finally turn on again.
Initially I thought it was the main control board. I replaced that, but eventually the problem came back.
I've done some research on this forum to try and figure it out. I've referenced the service guide linked here: https://www.applianceblog.com/mainf...-no-lights-on-control-panel.89244/post-461086
None of the flashing patterns described on the Main Control Diagnostics page 45 were accurate.
I kept searching and found this thread with my exact same issue: https://www.applianceblog.com/mainf...mc-board-flashes-1x-approx-2-5-seconds.95325/
2.5 seconds between service LED flashes, random beeps, then shuts down/goes dead. Exactly what I'm dealing with.
Next, I verified that the main control board is outputting 14.09V using this guide: https://www.applianceblog.com/mainf...-no-lights-on-control-panel.89244/post-461087
Should I still replace the UI board? Should I wait until it goes dead again and try and re-diagnose? Are there any other potential culprits?
Yes, anytime you get random beeps when the dishwasher is not in use, its ALWAYS the UI Board that is the culprit.
Here's the UI Board(at the top of the dishwasher door) for your model: WD21X31899 When you click the part link you will see a video that gives you the general idea of how to replace it.
I took your advice and it's been working without issue since. Just wanted to pop in and say thank you!
