GDF610PMJ2ES GE Dishwasher will not start
Tonya Dunsmore
Muncie IN
GDF610PMJ2ES
My dishwasher worked just fine & now will not start. Instead, it beeps 3 times. I have flipped the breaker for more than 30 sec. I followed your instructions found on internet pertaining to similar problem on a different model #. I have held down the Start & Select Cycle button for 5 seconds, all lights flash, the lock light stays lit in light red color. I hold the start & select cycle again & it looks normal again but still won’t work. I tried holding the Heated Dry button along with Start until the sound, then try to start it but it gives a different 1 time beep. So I cancel & it goes back to the 3 beeps after start. I do not see any water sitting, nor any dishes blocking anything.
Added complete model number
Hi Tonya,
You are missing a digit in your model number, please recheck it.
Here's the results I get:
GDF610PMJ0ES
GDF610PMJ2ES
GDF610PMJ4ES
GDF610PMJ5ES
GDF610PMJ6ES
Tonya Dunsmore
Muncie IN
I am just now seeing your reply. Sorry about that! It is working now! I took a few things out of the top rack to wash by hand, then was talking on phone about it to someone & I hit start. It worked! I’m wondering if it was beeping because it was too much weight. I don’t know because I know I have had it packed like that before. The correct # is GDF610PMJ2ES
Ok Tonya, sounds good.
Thanks for posting your correct model number, and thanks for the update!
