GDF610PSJ5SS GE dishwasher will not drain water
Ziploc1010
Atlanta
GDF610PSJ5SS
Hi the bottom of our dishwasher is full with water after a cycle. We tried cleaning the filter out. We tried using baking soda and putting on the rinse cycle.
Nothing is working. No matter what we do, after we vacuum the water out and try something else, the bottom of the dishwasher will not drain.
When its trying to drain do you hear the drain pump humming, but not running?
Did you remove the drain hose from underneath your sink garbage disposal and put the drain hose in something to catch water in and see if it drains into that first?
If the drain pump is humming and not running, you will need to remove the drain pump and check for a foreign object that maybe stuck/jammed in it preventing it from running.
This video gives you the general idea of how to access it:
Make sure you disconnect power to your dishwasher first!
