GDF620HGJ2WW GE Dishwasher Appears Dead But!
DIY_Husband
Indian Rocks Beach, Florida
GDF620HGJ2WW
GDF620HGJ2WW GE Dishwasher appears dead but if I recycle the power several times it comes alive for days to weeks. I'm guessing control board but sure would like to hear from someone with a similar experience. Iv'e checked all power and connectors nothing shows corrosion or issues. Just flipping circuit breaker a few times brings it back to life.
When it goes dead like that--->check your main control board STATUS LED, Tell us how many times its flashing in a row, or if it's STEADY ON or STEADY OFF.
To view the STATUS LED, remove the lower access panel of your dishwasher. You DO NOT have remove the control board from its metal casing when you view the STATUS LED.
--->Here's the main control board for your model: WD21X24900
Here's the video that show you how to remove the cover to access the STATUS LED on it:
When viewing it leave all the electrical connectors to it plugged in. If the STATUS LED is STEADY OFF, check to make sure you have 120 volts coming to it from where it says 120 VAC SUPPLY.
Ok, sounds good.:)
