GDF620HMJ2ES GE Dishwasher Dead - No Power
Tru483
Rockford, IL
GDF620HMJ2ES
D/W is only a couple years old but it seems the last storm did a number. This is direct wired into a 20a breaker. Breaker is not popped. I have verified power to the unit at the wiring junction behind the front panel of the D/W. I have dropped the main board tray and was unable to see any lights present. 1st assumption is the main board is DOA. How can I be certain?
Thank you in advance
Ok,
When viewing it leave all the electrical connectors to it plugged in. If the STATUS LED is OFF, check to make sure you have 120 volts coming to it from where it says 120 VAC SUPPLY. Use a multimeter to verify you are getting 120 volts there. If you are getting 120 volts there and the STATUS LED is STEADY OFF, then your machine control board is the culprit.
--->Here's the machine control board for your model you can order: WD21X24900
