GDF620HMJ2ES GE dishwasher not drying
Leondreed
Painted post ny
GDF620HMJ2ES
question for Jake
GE GDF620HMJ2ES not drying. Just replaced flood switch Jan 7. Could it be dirty? (Is this the cause?)
thanks!
Yes, it could be dirty or it went bad. To verify that--->First ohm test the flood switch. A bad flood switch would make it not heat.
--->Ohm your flood switch resistance with a multimeter set on 20K ohms.
the resistance across pins 3 & 5 on the flood switch should be about 11K ohms at room temp, and 1,300 ohms at 175 degrees.
These 2 circled in red are pins 3 & 5:
Here's the flood switch for this model:
WD21X10519 Switch Flood Asm
If it ohms bad and you just replaced it Jan. 7th you have a 365 day warranty on it if you bought it at AppliancePartsPros or RepairClinic
