- GDF630PSM3SS
- GE
- 1-5 years
Hello,
My dishwasher stopped working a couple weeks ago. It would fill with water but not circulate water or drain.
I went through the service mode tests and both the circulation pump and drain pump were unresponsive. The drain pump tested fine on my multimeter so went ahead and replaced the drain/wash pump motor fuse on the main control board. I ran the washer again and the replacement fuse fixed the drain pump but the circulation motor still did not engage.
Since I had no way of testing the circ pump for connectivity I replaced it. However, the new pump does not run either. The fuse is still fine as the drain pump still works. I also get 120 volts at the connector that goes into the circ pump and my main control board is flashing green.
I am out of ideas, appreciate any assistance.
-Neil
-Neil
