GDF645SGN0WW - GE Dishwasher fills (and drains). Circulation Pump doesn't commence
SJCN
Seattle
GDF645SGN0WW
Situation : Dishwasher starts. Sump pump drains standing water and refills. The timer counts through the full cycle. However there is no action with the circulation pump/wash arms. It doesn't begin. Dishes are not sprayed nor cleaned.
Previous Activity (and questions)
1. UI - I recently replaced the UI board in the door (no lights on the unit). Is there a PERSONALITY JUMPER SETTING that I have to set for this particular unit? If the Jumper Setting was incorrect, would this prevent the circulation pump from activating?
2. CEM - I did Consumer Error Mode (START/SELECT held down for 5 seconds). Lights go on. Hold, then turn off. How do I launch into the Consumer Service Mode to test if the circulation pump works?
3. Circulation Pump Test - I removed the circulation pump and tested with a direct power source. It works, with the Impeller rotating freely.
4. Tech Manual - I have a TECH MANUAL for units (GDF650SxJ0xx/GDT655SxJ0xx). Does this cover my model, or is there another that is more model specific?
5. Float - I have been told that a float could be stuck. Does this model have such a float that could prevent circulation pump from starting?
1. I'm not sure if this one comes with jumpers or not, this is one I've not seen before:
If it comes with instructions and jumpers, then the jumpers must be set per the instructions.
2. Here's the service manual: https://drive.google.com/file/d/15CmFe-hcufL5XUJPsqlEN3AzwDZ6z0M-/view?usp=sharing
Page 47 tells you how to enter Service Mode. NOTE: The dishwasher must be in Consumer Error Mode to enter Service Mode, Look on Page 45 to enter Consumer Error Mode first.
LED blink# 3 is circulation pump, see if the circulation pump runs.
If the circulation pump runs then its fine.
Remove the pressure sensor and see if something is semi-clogging it.
Here's the pressure sensor for your model:
Watch this video to access it:
SJCN
Seattle
Thank you very much, Jake, for the thorough reply, as well as the ideas on the pressure sensor. It was heavily used by the tenant, so good chance there could be junk in there. That youtube link is helpful.
I need to look at the ultra-fine filter, too, as I've read elsewhere that could prevent water flow to the impeller.
I was also told that a stuck 'float' could be a cause for holding things up, but couldn't find where one might be.
I will check after the holidays. Sending that technical manual is fantastic and much appreciated.
Regards, Simon
SJCN
Seattle
Hi, Jake. Thank you for your patience, while I postponed getting back to looking at the dishwasher until this weekend............
I removed the pressure sensor. There was nothing semi-blocking it, but it did seem that the internal diaphragm was stuck. I was able to loosen it up (so it seemed) by physically . I couldn't figure out, though, how to test it with my multimeter, Does it typically fail electronically?
I ran the dishwasher through the SERVICE MODE. At test point with #3 (Circulation pump), nothing was happening. Previously I tested the circulation pump while it was out of the dishwasher (using a power code/alligator clips), and the pump ran. Today, with the pump back in the dishwasher, running the SERVICE MODE, it didn't launch.
1. Is a failed pressure sensor enough to prevent the circulation pump starting - even when the machine has been primed full of water?
2. Is the harness a typical failure point that could prevent the circulation pump from working while in the dishwasher (even though it worked stand-alone on the workbench)? The sump pump is working with no issue.
Use the flow chart to find the culprit: Page 56 here: https://drive.google.com/file/d/15CmFe-hcufL5XUJPsqlEN3AzwDZ6z0M-/view?usp=sharing
Page 51--->Testing the Pressure Sensor.
