nadiaturley26
- GDP665SYN0FS
- GE
- 1-5 years
My dishwasher started cutting off after 1-2 minutes of running. There were no codes shown or any lights on. It started working normally for about a week and then started cutting off 1-2 minutes into the cycle and showed the code H2O.
I checked the pressure sensor, which was partially clogged, cleaned it. That didn’t work.
I read on here that it could be the machine control board, so I replaced that and I’m still getting the code.
There’s no kinks in any of the lines. Water pressure seems to be fine.
I also ran some diagnostic tests. The first test (drain pump) failed. The second test (water valve) passed. Then I ran the first test again and it passed?
