FIXED GDT605PSM0SS GE dishwasher keypad display not working
Roy d
Punta Gorda FL
GDT605PSM0SS
My 2 yr old GE, dishwasher started having a problem with the top light control panel! just want to make sure of the part I need to order, It was working perfect then one day nothing came on light wise, I unplugged it then it worked fine for a couple of day's then the same thing happened. unplugged it again it worked! this time did the same thing no lights come on at all the green light flashes' fast continually at the bottom it flashes so fast you can't count it. Please help!! power is all good at main circuit board.
Hi Roy, Get into Consumer Error Mode and let us know what happens. Let it run through the Door Check, then let us know if you get any error code per the LED's listed on the chart below.
Roy d
Punta Gorda FL
Finally had time to do some diagnostics on unit/ power going into main control board is 124 volts and power coming out to upper control board should be 13.5 volts but is only 8.9 volts/ bad lower board?
Yes Roy, you nailed it! Bad machine control board.
Here's the machine control board for your model you can order: WD21X25732
Glad to help Roy, keep us posted.
Excellent Roy, glad to hear the new machine(main) control board fixed it.(y)
