FIXED GDT655SGJ0BB GE Dishwasher Not starting, beeps three times
MADuke78
Rock Hill
GDT655SGJ0BB
Howdy. We have had this dishwasher for almost 2 years. Normally when you hit start, the orange light on the front will light up and stay on until the cycle is finished. Recently, when I hit the start button, the light will not come on, but after about 3 seconds it will flash and beep three times. The first couple of times this happened, we just flipped the circuit breaker and it worked when it powered back up. Now it will not. We've changed the water inlet valve and the door latch and it is still doing it. We've checked the water tubing going in and going out to make sure that there isn't a clog. Nothing is working. Is there something else that it could be?
Here's the tech data sheet for your model: https://www.dropbox.com/s/ynaoqi9oboud0lo/31-30792 GE GDT655SGJ0BB Mini Manual.pdf?dl=0
--->Check your main control board Service LED, Tell us how many times its flashing in a row.
To view the main control board Service LED, remove the lower access panel of your dishwasher.
--->Here's the main control board for your model:
Here's the video that show you how to remove the cover to access the main control board, and Service LED on it: Main control board access video
Make sure you leave all the connections connected to the control board when viewing the Service LED.
MADuke78
Rock Hill
Good morning. When I did the Select Cycle & Start test, all of the lights are flashing. Based on the service manual, I understand that means the door is not closed. 😕 I changed the door latch and the door is closed. Can the part that is attached to the door go bad as well?
You bet it can, that's why you have to see how many times your SERVICE LED is flashing on the control board. Without that information we are dead in the water.
You did leave all the electrical connections connected to the control board when you viewed the SERVICE LED? If so and no LED, then Yes, you nailed it, bad control board!
Order the control board I posted in link #2 and you should be back in business.
Excellent, glad to hear the new control board fixed it. (y)
