GDT655SMJ0ES GE Dishwasher Error 817 will not run
ShadetreeJR
Arizona
GDT655SMJ0ES
I have replaced control board and door latch.
Dishwasher still will not run. Any suggestions?
Check your main control board STATUS LED, Tell us how many times its flashing in a row, or if its STEADY ON or STEADY OFF.
To view the STATUS LED, remove the lower access panel of your dishwasher. You DO NOT have remove the control board from its metal casing when you view the STATUS LED.
When you have that panel lowered down turn the breaker back ON to your dishwasher. When viewing it leave all the electrical connectors to it plugged in.
So you get 0 volts at the control board?
If so, then you have electrical problem to the dishwasher. Check for 120 volts where you main power line to the dishwasher connects to. You should have 2 wire nuts where the main power connects to the dishwasher, see if you get 120 volts there.
