- GDT655SMJ0ES
- GE
- 1-5 years
Hello, Master Jake,
I believe I have a bad UI board.
Status LED is solid green...
However, I am posting as I believe this to be strange.
I just replaced the control board (WD21X24901) less than wo weeks ago after getting the 815 error.
It seems I am having issues after leaving the door open for a duration of time.
Prior to replacing the board, I would have intermittent issues after the door was left open, that a breaker reset often fixed.
Now, after replacing the board due to a stuck 815 code, and again leaving the door open (approx. 24 hr.), the UI board has no power or control.
Solid green LED...
Are these in any way relatable? or a crazy coincidence.
Logical next step is WD21X23462 replacement, however, wanted to check here first before $.
Solid green LED...
