Does the display lights and buttons work and respond when you press them?
Here's a similar thread:
The I'm having an issue with my GE GDT655SSJ5SS dishwasher. When I press start to start a cycle it does not start. Within about 4 seconds the dishwasher beeps three times then the small green light above the start button and the orange light in the center of the door flash together. The beeping...
www.applianceblog.com
Your model has the newer square control board, its located under the dishwasher towards the front right side.
Configured service machine control board WD21X25730 / AP6994874 made by GE
click.linksynergy.com
The new control board has a steady flash pattern on the service LED and only indicates the dishwasher has power and DC voltage is being produced by the control .
On the newer square control board you have, Look for the--->Service LED – There is a green LED on the control board that indicates the status of the control board. See if that green LED is flashing or STEADY OFF.
Here's the instructions to access it:
Here's the UI Board for model:
Configured Ui Board WD21X32000
