TreeFarmer
- GDT665SMN0ES
- GE
- 1-5 years
Our GE GDT665SMN0ES (~2 years old) will startup and drain (I replaced the drain pump, and I can hear it drain). Then it sounds like something is running, drain or water, and then it just shuts off. It does this for all cycles.
When I go in to the diagnostics I see Error Code 56. Then when I run the system self tests, no problems are found. Then if I exit and go back in to diagnostics it shows 00. However, running a cycle will error out again. Is this a problem with the pressure sensor or something else?
