Jake, I always believed you. I was just having a problem finding the original board. When I found a board on eBay I purchased it with trepidation. After installation the DW ran but, had some symptoms of the UI I replaced. I had purchased the updated board when I found out GE had a new board. I have now installed the updated UI board when the older version UI failed again or appears to have failed. I have set the jumpers on the UI according to the instructions. I now have a what appears to be a communications error between the control board and the UI. The UI responds with the 3 beeps and the flashing LED when it checks for a open/closed door. Out of superstitions I replaced the door lock still the no start flashing LED. of course that failed to solve the no run. I have checked the continuity on the door switch at the board, 3 pin to the 4 pin and 5 pin checks open when the door is open connected when the door is closed. I was looking for a bad harness from the switch to the board. I have a working latch and harness. The control board has a steady burn LED indication per the mini service sheet a software error replace board. I had a second control board so I installed the other board same steady burn.
So, I have a new UI, the updated version, a new control board, I bought one due to my error in checking for voltage to the UI and a new door latch. Where do I need to look now?
Update: I have checked the wiring harness from the UI plug to the control board, no broken wires. I have continuity on each wire at the plugs. I have reset the number 4 jumper to off, jumpers 8 2 1 are on. Installed door plugged in all connectors to the control board. Run error check , Select Cycle and Start held together, all LED's flash then lock LED is lit. The control board still has a steady LED lit. Which board is bad? Or what do I check now?
