GDT695SSJ0SS GE dishwasher not starting
smarkle
Kansas
GDT695SSJ0SS
Door latch sensor replaced and dishwasher still won’t start. Controls light up, but when ‘start’ is pressed and door is closed, dishwasher won’t start and just blinks and beeps like door is still open. Please help!
--->Check your main control board STATUS LED, Tell us how many times its flashing in a row, or if its STEADY ON or STEADY OFF.
--->Here's the main control board for your model: WD21X24901 Machine Control
Restore Power, then make sure the door harness connector is attached to the bottom of the control board casing connector when you view the STATUS LED light, Also make sure the 120 volt connector to it in the front is still attached to it also.
Let us know.
Ok, Then the machine control board is the culprit.
Here's the machine control board for your model you can order: WD21X24901 Machine Control
Thanks for your help! Got it ordered and will hopefully have it installed and back running today!
Ok sounds good, let us know how it goes.:)
