Jpeck
- GDT695SSJ5SS
- GE
- 1-5 years
Hello. I've read a lot about issues people have with their GDT695SSJ5SS. Symptom: It has been periodically "waking up" and a few times no apparent life unless I unplugged it and plugged back in to "reboot". Now no activity on UI - no apparent life. I have the square MC board. LED light flashes quickly.
Question: Is there a way to use a multimeter to see if there's the required 14v on the board similar to how you can determine on the other model boards (the #2 and #5 pins)? The manual indicates if LED flashes 7x per second, it means software error, replace MC. So i ordered a new MC (will get next week) but then read somewhere on here that the manual is wrong. The issue is the UI board. Is that accurate? Should I be replacing the UI instead of the MC? Thank you!!
