FIXED GE Adora DDT595SMJ2ES Dishwasher No power up
Mtbxdrew
Maine
DDT595SMJ2ES
Went to do a load of dishes and nothing on the display, I have house voltage to connector at main board under the unit, green LED lit constant no flashes, no change when trying to enter service mode, thinking the logic board in the door? Any help is appreciated I don’t want to sling parts at it
Mtbxdrew
Maine
Also I should mention for the last few weeks it would randomly sound the chime like I had pressed a button, keeping the unit shut seemed to stop it
Hi, If the control board STATUS LED is STEADY ON--->UI personality not set, communications lost between UI and MC
The UI operational voltage is output from the main control board on connector J722 pin 2 black/green to pin 5 yellow/blue. If 13.5 VDC is found here, then the UI Board is the problem.
Here's the user interface(UI) board for your model you can order:
WD21X23461 Kit Svc Ui Top Logic
That J722 connector is on the other side of the control board, look here:
It's the one on the left above the ethernet port.:)
Yes, you will need to order and replace the UI Board and that will fix it.
The new UI Board will come with instructions to set the jumpers per your model number. The jumpers must be set properly or it will not work.
Do you need instructions to replace it?
Mtbxdrew
Maine
Great thank you, I have the board out, what a pain to take the door apart, I’ll let you know if this fixes it
Yes, it is a pain to take the door apart.:)
Yes, keep us posted. Remember to set the jumpers first per the instructions it came with.:)
Excellent, glad to hear the new UI Board fixed it. (y)
