GE Advantium Microwave PSA2200RWW02 - Press knob will not respond
kstinmb
SC
PSA2200RWW02
Hello, GE Advantium Oven - Model PSA2200RWW-02 - S/N VV300025K (Purchased December 2011)
The control panel does not respond to knob press. I can select a function on the touch pad (example Microwave), then turn the knob to the next level menu choice (example Popcorn), but it does not respond to pressing the knob.
In 2017 I replaced the Controller Panel (PN WB07X11315) because the touch panel was inoperative. It has worked fine until recently.
The Selector Board is a small printed circuit which holds the selector knob with a pig-tail, but the Technical Manual does list a part number. The photo (below) has two numbers.
Can anyone help with a part number and source for the Selector Board?
Thanks for your assistance,
KSTinMB
Stephen in Myrtle Beach SC
Here's the Selector Board, seen from the back. There's a knob and circular selector on the other side.
Who can help me with a source and a part number? (I have tried the partially visible numbers in the photo with no success).
I found a "Rotary Encoder Board" on eBay, but it has another part number (Rotary Encoder Board for GE Advantium PSA9120/9240 P/N WB27X11022 WB27X32632)??
https://www.ebay.com/itm/124801538759 Is this the same part??
Press "Microwave" on the control panel, gets you here. Rotate the knob for a selection, but pressing the knob does not work.
WB27X11022 was the original number for that part on your model. It has since been substituted to # WB27X32632. Neither of those numbers may be stamped on the part itself as it is made by a secondary manufacturer whose own item number may only be stamped on it. I have no idea if the part displayed is either of those numbers but very well could be.
You can see a photo of the actual part here:
This link is pertinent to the topic. It is supplied by the message author:
LINK > WB27X32632 Board
