GE Cafémodel CYE23TSDCSS is not cooling fresh food or freezer sections with new MB and inverter
FrankWarmFridge
Tampa
CYE23TSDCSS
Hi I hope you can help me determine what is going on with my refrigerator. I have an 8 year old GE Café refrigerator model CYE23TSDCSS is not cooling in fresh food or freezer sections. Following instructions in technical service guide, I got the following diagnostic test results:
  • 47 FF Fan Test – 3427
  • 48 FZ Fan Test – 2499
  • 49 Condenser Fan Test – 1663
  • 61 Compressor Relay Test – Test Executing
  • 95 FF Cooling Test – 75.57
  • 96 FZ Cooling Test – 75.52
I replaced the compressor inverter and had the same results.
I then replaced the mother board and it’s still not cooling in in both FF and FZ zones.
Here are my readings:
  • Tested 3 leads on compressor and all have 6.8 ohms resistance
  • From the main board, J9 jumper connector 7&8, specs say 2-3: New MB 2.69v - PASS
  • When I disconnect control wire to inverter specs say 4-5: New MB 4.34v - PASS
  • Power to the compressor is 121 VAC
  • After reconnecting control wire, I feel compressor start with soft vibration
  • Condenser coil is clean and condenser fan working.
Both copper lines in/out of compressor are at room temperature.
Is this indicative of a bad compressor? Or a leak in the copper lines?
Thank you,
Frank
  • GE CAFE_31-9227.pdf
That's a indication of a sealed system problem.
The sealed system consists of the compressor, condenser, evaporator, heat exchanger, filter/drier and refrigerant.
Common problems with a sealed system are bad compressors, refrigerant leaks, and system restrictions.
Check your owners manual warranty, some models have up to a 5 to 10 year limited warranty on the sealed system parts.
FrankWarmFridge
Tampa
I appreciate the information Jake. I will need to contact a technician to troubleshoot and check for leaks since I don't have the proper equipment.
I will keep you posted.
Thank you, Frank
Ok Frank, sounds good.
