FIXED GE Cafe CGS990SET5SS Oven igniter glowbar problem
Marco maser
Woodbridge
I am officially joining this club. We purchased a GE double oven range PGB995SET2SS in 2013 as part of a complete kitchen remodel. Actually it was a remodel of much of the house. The igniter is the latest in line of things I replaced that failed, including:
Both new bathroom toilets (rebuilt both inner tanks replacing everything)
Master Bath vanity/sink (water rolled off onto floor, replaced entire thing)
Master Bath faucet (valves replaced)
Main Bath faucet (Handles and tailpiece disintegrated, replaced both)
Main Bath towel bars (Stainless steel rusted! Fought with manufacturer for replacement)
Dishwasher (display panel failed, due to design defect, fought with manufacturer for replacement. A new rinse aid dispenser is on its way now.)
Now I can add the oven to the ever growing list. The oven is on a GFI circuit. It kept tripping, so I replaced the GFI. The new one tripped once. The oven then stopped working.
I installed a new igniter. I was getting ready to put the oven panels back in, but I started to wonder about how all the extra metal got on the old igniter. I looked under the bottom panel at the heat deflector and saw dreaded reverse volcano looking at me, saying, "yeah, I am against you too."
"You've been talking to the dishwasher, for sure," I said. So many of the remodeled items have failed, I find talking to them is good therapy.
Anyway, I then found this forum. Thanks to all who have been subjected to the punishment of GE and reported it. I just want to add that after seeing the replacement heat deflector, I saw it was the same as the one I currently have, but with a rectangular area taken out of it. Very interesting. I suppose the stainless shield must have a higher melting point? I am sure GE has tested this fix thoroughly and has the data to back it up. They are professionals, after all. Hopefully they were putting more resources into jet engines that day.
So I cut the deflector I had to remove the piece that GE removes now. I looked a the part on a website that had it on a 1" square grid and figured out where to cut. If anyone is interested in doing this, you could save a few bucks. I did just out of principle. I mean, this thing cost a lot of money! It was not purchased at Big Lots, I can assure you of that. I really should not have to be doing this.
I have attached a file showing what I did, in case someone in the future stumbles upon this and wants to do the same thing.
One last thing--you do not need to use the same exact igniter. It is a pretty generic design used by many manufacturers. You can buy a cheaper one, but you may need to remove the old metal "cage" from the broken igniter and place it on the new igniter. Be careful! The igniter is very brittle. Maybe get your brother to do it, so if he breaks it, you can blame him. Also, you can cut the wires from the old igniter and tie the new one in using ceramic wire nuts. The wire nuts should come with the new igniter. DO NOT USE PLASTIC ONES!!! I had to strip double the length on the wires from the new igniter and fold it over. This, along with the wires from the range gave enough thickness for the wire nuts to securely tie them together. You can do a quick search on youtube to see people installing igniters this way. Make sure to push the wire nuts through the back hole past the insulation. Don't leave them in the oven area.
I followed exactly what you did and made the same cut out on my existing deflector. The one question I have however is when you reinstall this deflector back do you install the copper sheild deflector back on top of this. Hope I’m being clear enough here, so there is the bottom oven assembly which is removed, then there is the copper sheid in between this assembly and the deflector that I cut. Do reinstall this as well back the same way to which I removed it? Your help would be greatly appreciated. Thanks
Oregongirl357
Central Point
Please add me to this thread. I'm having the same issue. Mine is a couple of years old and I just ordered a replacement heat shield and igniter.
Oregongirl357
Central Point
I have an update to this thread. GE has redesigned the heat shield increasing the cut out size to 4". Also, it came with detailed instructions on how to properly install it with a few extra warnings about installing it incorrectly. I am 100% certain that mine was installed incorrectly originally from the factory as this is the first time it's been replaced and the melted/burned section was opposite and diagonal from the cutout and clearly directly over the igniter. Also agree with others that have noted the screws get damaged with heat - I had trouble extracting over half of them. Fingers crossed that the problem is solved.
Fuelpowered
United States
Update 2019 April
GE has allegedly fixed my range. Replacement of electronic guts and a revised heat shield with new igniters. They say that this is it and that it should run flawless for the rest of it's life. That's what they tell me.
Mashman
Austin
Well, now the upper oven is working. Go figure.
I'll add that this is the second time that the lower oven igniter was replaced. The first time was by the appliance repair from whom I purchased the unit. He replaced the igniter but not the deflector shield, so I don't know if there was a "hole" burned into the deflector shield at that time.
I seem to be in the same boat, did you find a solution to this problem?
I had the issue with the igniter burning the hole in the shield, and fixed that, but now the upper oven will not heat up. When I turn it on the light comes on and the heating light comes on for a few seconds, but then it turns off. I replaced the thermostat and that fixed the issue for a short time. It seemed to work and heated up, but when I turned the oven all the way up, and let it run (kind of a stress test) I cam back after about an hour and it was doing the same thing. Something that happened when the igniter shorted that is causing upper oven thermostats to go bad.
Note - when the issue first occurred we hired a repair tech who came out and was worthless. He took the oven apart, said he couldn't fix it, didn't put it back together, told us to buy a new oven, and charged us $500! After that is when I found this thread and fixed the igniter myself! But one thing he did say that is interesting is that he said he found a relay melted. He replaced the relay and when that didn't fix the oven I guess that is when he gave up - I don't know if he even looked at the igniter.
I only know of one relay(WB13K10050), I think I'm going to try replacing that relay. Does anyone have any other suggestions?
TomFrustrated
Alabama
Hi All, interesting topic. I have the same problem with igniter going bad and melted heat shield that was installed backwards from the factory. The first igniter failed the week the warranty ended. I called GE for help and the lady was very nice but was unable to contact-locate a technician to help me troubleshoot the oven. I was calling on a Friday evening and she told me I would need to call back Monday morning. She also told me me my warranty was up the next day on Saturday.
I was concerned that I wouldn’t be covered under warranty when I was to call back on Monday. I was right to be concerned. I asked the lady for her name and a ticket number of my call as proof that I called before the end of my warranty period. She would not give me her name or a confirmation number of my call and assured me it would be a problem. I called Monday and was told I was out of warranty and the repair wouldn’t be covered and there was no record of my call on Friday. I was very upset to say the least.
I ended up googling the problem- replaced the igniter and shield myself. It worked for about 6 months then went out again. I replaced a second time and it lasted 3 months and now after 2 days its gone out again. I think it’s time to go back to Chinese products because I’m going broke buying American made -green tractors, Ford trucks, and GE. :(
bigbuck
From Planet Mars
Your ok then! GE Appliances. GE Appliances is an appliance manufacturer which is owned by Chinese company Haier, a global appliance manufacturer based in Qingdao, China.
pdudley1972
Vancouver
This thread helped me get to the bottom of my stove problem. After the 2nd ignitor I bought burnt out after 1 month I took the plate off and flipped it upside down. Low and behold the same problem that everyone else had. A melted out hole...looked like a volcano. So off I went to the workbench to cut it out and create my own opening. That worked fine. Went to reinstall it and noticed that there already was a section cut out of it!!! Thinking I had installed it the wrong way I took it out and looked closer (I remember reading here that someone said the new plates already had a cutout). So, the long and the short of it, Sears (who went bankrupt in Canada a few years ago), installed the upgraded plate (based on redesign due to complaints) flopped 180 degrees. So those idiots could have just turned the frickin’ thing around and I wouldn’t be in this situation. So now my deflector plate now has two sections cut out. Oh well. Seems like the customer has to figure everything out.
awilki
Maryland
I experienced the same problem. Bought my first one in 2013 direct from GE, and after 4 repairs, GE refunded my purchase, and I foolishly purchased another one. Once again, 4th repair called in. I purchased the second one from Home Depot and their extended protection will refund 100% under the lemon protection plan. I have made many calls to GE and will push this to the very top for exposure. Its clearly a design flaw, yet they claim they are unaware of the issue every time I call. If anyone has has success in reaching someone at GE that can actually be in a position to properly respond, please post it here, as I will when I do. I absolutely love this dual range, but would not buy again, unless I can be assured the issue has been resolved by GE.
Mashman
Austin
FOLLOW UP - all is now good.
The issue WAS the relay. Once I replaced the relay the lower over started working again!
awilki
Maryland
Our top oven also had stopped heating, but it was a simple matter of replacing the thermostat, and the bake igniter in the lower oven.
We just had the lower oven repaired again yesterday. Thanks to this blog, I had him check the heat shield, and he discovered that the igniter melted the shield above it, as the installation was improper. It was installed backwards, so the cut-out above the ignitor was on the other side, and not above the igniter. I reached out to GE, and have to say, they have been great! They expressed to me the parts free of charge, and now it looks like they will be reimbursing me the labor cost as well. 3 years outside of manufacturer warranty!
jm1fd
Texas
By what method did you reach out to GE? I'm suffering from the same defect as everyone else in this thread and I'd like for GE to cover the cost of the parts, and I'm wondering what the most effective way to get their attenton is.
Mashman
Austin
SORRY - I ment to say the UPPER OVEN started working again.
When the igniter shorted it apparently broke the lockout relay. This caused the upper over to not work - it would turn on, the heating light would come on and after a few seconds the heating light would turn back off. Once I replaced the lockout relay the upper oven started working again.
Go to their facebook page and send them a message:
Let us know if they respond.
Excellent, glad to hear that. (y)
