GE Cafe Dishwasher CDT725SSF6SS drain pump codes
Allanb23
Colorado
CDT725SSF6SS
My GE cafe is throwing a couple codes .
They say it’s the drain pump.
I replaced the pump and cleaned out the drain hose that was pretty clean.
when it throws the code it stops working . There’s standing water in the bottom. I cycle it and it will drain. I even filled it with water to make sure it worked and pumped it out the disposer.
I couldn’t find a schematic so I don’t see what controls the pump to possibly change out . Some type of limit switch or sensor .
Any help would be greatly appreciate it
Thank you in advance
Allan
Allanb23
Colorado
Here’s my update
The drain pump has 0 ohms across it . I had just replaced it . It should have had 26 ohms across it. What are the odds I get a bad one
this pump does cycle some then shuts off and throws a code . It will drain a about 1/2 gallon of water I pour into the bottom
Allanb23
Colorado
Will the pump run at all if it’s not ohming out , because this will drain then go into fault
No, the drain pump will not run if it failed the ohm test.
