GE Cafe dishwasher drain hose instalment question - am I missing a part?
ktaylormusic
Ontario
GE Cafe no model
I'm installing a used GE Cafe dishwasher - about 4-5yrs old, apparently. No model number to be found.
When I go to attach the drain hose, there is a threaded connector on the dishwasher side, but no threads on the rubbery black elbow connector on the hose side. This is making me wonder if there is a part missing here. (The dishwasher I took out is so old it's hard to compare.) I've attached pics of each side, as well as the whole bottom in case that helps anyone recognize the model. It just seems odd to clamp this rubber hose end over a threaded mount, as if something else is meant to happen here and, if nothing else, be a source of leaks. Also, it notably says ON the drain hose "do not remove check valve", so I'm wondering if that's what's missing.
Also, if anyone recognizes this model number, it would super help to have it if I need to buy a part!
Any help or guidance would be much appreciated.
Look inside the door on the tub frame for the model number tag, without that model number we are dead in the water.
