GE Cafe Range CGS750P4MW2 Control Screen Error
timloco
los angeles
CGS750P4MW2
Hi all,
My Cafe Range CGS750P4MW2 is just a little over 1 year old. Today, the control screen won't respond no matter what key I push. It doesn't show any error message. Just has two brackets on the top right and botter right corners. The top oven did start at a very low temperature for couple of minutes and then stopped.
The gas stove is working, but the ovens are not since they are controlled by the screen.
I have no experience with that model but found this online:
The Interweb said:
That backwards bracket means that your oven is in Sabbath mode. All you should need to do to exit Sabbath mode is press and hold the "Settings" button for 5 seconds. That should exit Sabbath mode, and then you can use the oven like normal again. If it isn't working, then you can unplug the oven for 5 minutes and try again.
If in Sabbath mode, I believe it only lasts 24 hours at most. (Your actual directions may vary. Check the owner's manual.)
