GE Dishwasher CDT765SSF1SS - Still getting F96 fault after new turbidity sensor.
dweezil
Kirkland, WA
CDT765SSF1SS
So just finished replacing the main board, flood sensor and turbidity sensor. However I'm still seeing intermediate cleaning issues and a F96 fault code.
Next steps? Pull and test resistance on the sensor and wire harness back to main board?
Chris
dweezil
Kirkland, WA
From a similar thread:
"The Turbidity Sensor should be 10 ohms. So if you got no ohm reading on your meter at J703 between the Violet to White/Red wires, then its definity the hidden heater that is the culprit."
So I'll measure and report back.
Yes, I remember that thread.:)
Here's the variable speed pump, (with the hidden heater inside it) for your model too, in case you need it:
