FIXED GE Dishwasher GDF510PSJ2SS unresponsive
RROBBIE
GDF510PSJ2SS
Controls appear to dead. When pressing the START and CYCLE buttons simultaneously to a count to 5, all UI lights flash 9 times, then appear to be dead. The door latch/switch has been replaced. There is power at the UI board.
RROBBIE
WD05X24776 has been ordered. I will let y'all know the outcome. Thanks for your help
Ok sounds good, yes let us know how it goes.
RROBBIE
New heat element installed, still appears dead.
However, when in consumer mode, door closed, all LEDs are on (count of 10), then go out except the "LOCK" light. Control board LED is solid green. Turn off "LOCK" and control board flashes 7 in 3 seconds.
Reset the CSM.
To determine if the CSM is tripped, enter Consumer Error Mode.
Press the Select Cycle and Start buttons at the same time for Five (5) seconds. If the control responds with LED’s or Display coming on, The CSM is tripped.
To reset the CSM.
Entering Service Mode will reset the CSM.
To enter Service Mode:
1. First enter Consumer Error mode as directed previously. After the ten (10) second door check has completed, continue to next step.
2. Enter Service mode (while in Consumer Error Mode), by pressing and holding the Select Cycle button for five (5) seconds.
RROBBIE
Thank you Jake.
Your help is most appreciated. CSM reset and the dishwasher is working. I just had to be patient. Thanks again.
Excellent Robbie, glad to hear that.(y)
