GE Dishwasher GDF520PSJ4SS Not running/No lights/Solid Green LED on board
rsidwell79
Springfield, MO
GDF520PSJ4SS
Hello,
I have a GE GDF520PSJ4SS dishwasher that was doing the random wakeup (3 beeps) for a couple months. I didn't pay any attention to it, then the machine went completely out. No lights, will not run, solid green LED on the control board. I tried the reset pushing the start/cycle button for 5 sec and nothing. Replaced the board with a new WD21X24900 and still have all the same problems to include steady green LED on the new board. Any help is appreciated.
Thanks in advance,
Rob
Hi Rob,
If the machine control board STATUS LED is STEADY ON, that indicates the UI(User Interface) Board is the problem.
--->Here's the UI board for your model you can order: WD21X23463 Kit Svc Ui Front Logic
There is a video in the UI Board part link that shows you how to replace it.
Remember to set the jumpers on the new UI Board before you install it. The instructions always come with the new UI Board and shows you how to set the jumpers.
--->If the personality is not set by using the 4 jumpers, the buttons, LED’s or cycles will not function properly.
Like I mentioned in post #2--->There is a video in the UI Board part link that shows you how to replace it.:)
Ok, sounds good!
