GE Dishwasher GDF570SSJ0SS will not cycle to drain cycle drain..
CLOVERCRAZY
Tulsa
GDF570SSJ0SS
I have a GE GDF570SSJ0SS that when you push start it will fill with water but then nothing... I took the drain pump off and there was a toothpick inside the impeller area. Took that out still didn't work so I thought maybe it burned out the drain pump motor.
I ordered a new drain pump and installed today and it still does not work fills with water then nothing but it will play the chime a couple hours later like its finished washing even though nothing happened.
I checked the status LED light and it blinks green once every 3 seconds. I checked all my hose lines and there is no blockages. I'm not sure what else to do.
Hi, Sounds like the circulation pump(wash motor) went out, lets verify that.
Here's the service manual for your model: https://drive.google.com/open?id=1M-G9W3HiaYnihdB5Cy-jfSPoVf8DZ7j7
Do this--->No Circulation Flow Chart on Page 55.
Here's the circulation pump(wash motor) for your model you can order, if needed:
