- GDF610PGJ2BB
- GE
- 1-5 years
The GE [GDF610PGJ2BB] dishwasher started not draining water 2 weeks ago. I ordered and replaced the drain pump. After installment of the new drain pump, the dishwasher fully cycled 2x with no problems. The 3rd time it cleaned the dishes, did not dry them, and the drain pump began cycling continuously.
The drain pump only cycles continuously when the start button is not selected and the door is fully closed. In addition, after pressing start the dishwasher will no longer run a cycle to clean the dishes. After pressing the start button I hear two clicks, see a green light under the unit, the drain pump occasionally comes on, and the timer continues to count down.
When I open the dishwasher after waiting 15-30 minutes nothing is wet, hot, or clean. I have cleaned the filters and searched for other posts on this forum. Does this sound like it might be the Flood Switch Assembly? If not, any other advice on parts to check or replace?
Thank you for any advice you can offer!
