GE Dishwasher GDF610PMJ2ES Not Heating
Owentp
Michigan
GDF610PMJ2ES
I recently had the water off to my dishwasher for a sink repair. I forgot to turn it on and cycled the dishwasher. Everything still works, but it will not heat up and dry the dishes. I have replaced the heating element & cleaned the float switch. Did I fry something by not having water run to it?
I have heard of a high limit thermostat but no part comes up for this model online. Any suggestions would be welcomed.
Hi, if the flood switch is bad, the dishwasher will not heat on these GE models. Do you know how to access it and ohm test it?
Here's the flood switch for this model:
WD21X10519 Switch Flood Asm
You can ohm test your flood switch resistance with a multimeter set on 20K ohms.
the resistance across pins 3 & 5 on the flood switch should be about 11K ohms at room temp, and 1,300 ohms at 175 degrees.
These 2 circled in red are pins 3 & 5:
Ok Owen sounds good, let us know how it goes.
Owentp
Michigan
Well.....flood control switch & new element installed, used rinse aid & still not working! Must need a control panel.
Ok, It will really be good to ohm test your original parts before ordering new parts.:)
You also have a TCO(Thermal Cut Off) if that is bad even a new control board will not make it heat without replacing that TCO too if the TCO ohms bad. So if don't have a multimeter to ohm test, then order both the TCO and the control board.:)
The TCO is located on the right side of the tub, approximately 16 inches from the front of the tub.
The TCO is held in place with two 1/4 in. hex head screws. The TCO is in a series circuit with the Calrod Heater.
Here's the TCO for your model: WD21X21690
Here's the main control board for your model: WD21X24798
Owentp
Michigan
Do I have to replace the board if the TCO is replaced. I did test all the old parts with a multimeter & they all seemed to be in range.
Owentp
Michigan
You said it is on the right side 16" from the front? The part you gave me shows it is in the same area of the control board in the front and it's a harness??
On your control board the wire harness that the TCO is on is at the J702 connector.
The TCO only comes with a new wire harness:
See it in the photo above on the left side with the Violet wires going to it? And the metal mounting support brackets attached to it?
Its will show you a more detailed diagram of its location on page 67 here: https://drive.google.com/open?id=1XTOXM0wA0UJEuucW0deIni17sMPtDGtD
Owentp
Michigan
Thx! So I'll get the harness & the TCO.....correct. This makes sense since it ran w/o water that it should have tripped.
Yes Owen, get the TCO and control board and you should be back in business.:)
