GE dishwasher GDF610PMJ2ES only runs for a couple minutes, then shuts off
Philzyo244
Ohio
GDF610PMJ2ES
Hello,
My GE dishwasher GDF610PMJ2ES will run for a couple minutes, then shut off. The control board was replaced a couple months ago after determining it needed replaced by using this forum - https://www.applianceblog.com/mainf...ill-not-start-2-flashes-on-service-led.82401/.
The control board was replaced as instructed and it was working fine for a couple months. Now, it will start but will only run for a few minutes and then shut off.
Any help is greatly appreciated!
Phil
Ok Phil,
View the STATUS LED on the control board to see if its STEADY ON or STEADY OFF, or BLINKING a pattern.
Did you buy it at AppliancePartsPros?
Blinking what pattern?
1x per 3 seconds?
2x per 3 seconds?
3x per 3 seconds?
4x per 3 seconds?
and so on?
Philzyo244
Ohio
It is blinking 7 times in a row, then resting for a second or 2.
If I'm trying to count while it blinks, I would have to guess between 4 and 5 times within 3 seconds.
Ok, 7x per 3 seconds--->(CSM)Current Sense Module is tripped.
I located a service bulletin on your model for this problem, but we need the serial number of your dishwasher to verify it.
CSM (Current Sense Module) Causes No Operation or Dead Condition Dishwasher--->A heating element or random non dishwasher faults may cause the CSM to trip and render a dishwasher in a no operation or dead state.
The service bulletin dates that apply--->(May 2015 April 2018).
Yours was made in October of 2016.
Press the Select Cycle and Start buttons at the same time for Five (5) seconds. If the control responds with LED’s or Display coming on, The CSM is tripped.
Or
Access the main control board and view the service LED. If it is flashing 7 times within 3 seconds, the CSM is tripped.
REPAIR--->Replace the Heating Element with WD05X24776
Heating Element WD05X24776
  • DD02-18.pdf
Glad to help Phil, Let us know how it goes.
Remember to disconnect power to your dishwasher first before replacing it.
