GE Dishwasher GDF610PMJ2ES works a couple of times then it will not power on a few days later
spikey
deerfield beach
GDF610PMJ2ES
my dishwasher works a couple of times then it will not power on a few days later. i replaced the control board thinking that was the fix. after reading the Technical Service Guide 2015 Plastic Tub Dishwasher i discovered there is a LED that indicates what the issue may be. how do I see that LED on the control board? It seems as though i will have to remove it while it is still powered. thanks. you guys are very informative and save me some $$$
The control board is located underneath the dishwasher, just remove your bottom access panel and then remove the metal cover from the front of it, and its in there.
To view the main control board STATUS LED, remove the lower access panel of your dishwasher.
Here's the video that shows you how to remove the cover to access the main control board, and view STATUS LED on it: Main control board access video
Don't remove the control board from its metal casing.
Make sure you leave all the connections connected to the control board when viewing the STATUS LED.
That is correct.
spikey
deerfield beach
good afternoon jake. i finally found that the led on the main control board is steady green. no blinking. none of the controls on the display panel work or illuminate at all. can you give me an indication of what that steady green light points to? thanks for your support. john
Ok John,
If the STATUS LED is STEADY ON, then the UI(User Interface) Board is the problem.
Here's the UI Board for your model you can order: WD21X23462 Kit Svc Ui Top Logic
--->The original board does not have jumpers. You need to set the jumpers on the NEW UI Board per the instructions THAT COME WITH IT.:)
I moved your refrigerator to a new thread here:
