GE Dishwasher GDF620HMJ2ES Won’t start
Meyers
GA
GDF620HMJ2ES
Buttons work, but dishwasher won’t start.
When I close it, I’m not hearing a sound (and I think I usually do).
Lights do not blink. Everything looks normal .... except that it doesn’t start.
--->Check your main control board STATUS LED, Tell us how many times its FLASHING in a row, or if its STEADY ON or STEADY OFF.
--->Here's the main control board for your model: WD21X24900
Restore Power, then make sure the door harness connector is attached to the bottom of the control board casing connector when you view the STATUS LED light, Also make sure the 120 volt connector to it in the front is still attached to it also.
Ok, If the control board STATUS LED is STEADY ON--->UI personality not set, communications lost between UI and MC. You will need a multimeter to check for 13.5 Volts DC.
The UI operational voltage is output from the main control board on connector J722 pin 2 black/green to pin 5 yellow/blue. If 13.5 Volts DC is found here, then the UI Board is the problem.
Here's the UI(user interface) Board for your model: WD21X23462 Kit Svc Ui Top Logic
Connector J722 is located on the metal casing side of the main control board.
It's the one on the left above the ethernet port.:)
Meyers
GA
Thanks... but, I didn’t read the initial instructions fully the first time. So sorry. Re-read them tonight and followed them.
I’m doing so, there is no LED light on at all. So, it would be STEADY OFF.
I apologize for the confusion.
Ok, STEADY OFF indicates the main control board is bad.
--->Here's the main control board for your model you can order: WD21X24900
Do you know how to replace it?
Meyers
GA
Thanks so much! We ordered the part. It arrived today, and we installed it (after watching a couple of videos). Our dishwasher now WORKS! Thank you so much for your help!!
