Atvkid4eva
- GDF630PSM3SS
- GE
- 1-5 years
I have a relatively newer GE dishwasher Model # GDF630PSM3SS, Serial # DR715721B
Out of nowhere the dishwasher has become unresponsive as in none of the buttons light up like normal and it will not turn on like normal. However if you press the buttons enough and toggle the power on and off at the wall switch it will power on and begin to run. It will get about half way through the cycle and then lose all power. I have verified that there consistent power to the outlet which it is plugged into, it is not an issue with the circuit. Once it shuts off mid cycle, nothing will illuminate and if you mess with the buttons enough and toggle the switch on the wall some more it will come back to life and run a little more then lose power again. It usually loses power at the point where there is hot standing water in the bottom of the tub.
After Reading some similar posts on here I did go into service more and verified that the door latch is functioning like it should and then ran the dishwasher in manual mode and verified the various functions work. I thought maybe this would bring it back to life, but none the same thing happened right after.
Thoughts?
Thoughts?
