FIXED GE dishwasher GDT545PSJ2SS no power to buttons, main control board has solid green status light
Austin fixit
GDT545PSJ2SS
The dishwasher has no power to the buttons the main control board has a solid green status light I have cycled the power and made no difference
Ok Austin, Let's check voltage to the UI Board.
The UI operational voltage is output from the main control board on connector J722 pin 2 black/green to pin 5 yellow/blue. If 13.5 VDC is found here, then the UI Board is the problem.
Here's the user interface(UI) board for your model:
WD21X23461 Kit Svc Ui Top Logic
That J722 connector is on the other side of the control board, look here:
It's the one on the left above the ethernet port.:)
Ok, so your machine control board STATUS LED is STEADY ON too?
If so, do what I mentioned above to Austin in post #2.
Your model uses the exact same UI Board I posted in post #2 as well.
Yes Mark, exact same procedure on yours too.
Only difference is your UI Board is a different part number.
Here's the UI Board for your model: WD21X23462 Kit Svc Ui Top Logic
Excellent Mark, glad to hear the new UI Board fixed it.(y)
