- GDT545PSJ2SS
- GE
- 1-5 years
When pressing start, there's a pause, then Start flashes, amber in front flashes, and there are intermittent beeps.
I entered CSM, see code 817 display. I close door and the top lights continue to flash. Then, all lights off except for top amber "Lock Controls" light. Then back to regular display,
I just replaced the UI based on some threads I read here, worked for a few cycles, thought I had the problem fixed!
I forgot to mention, I checked the main control board - led is steady off.
However, it was always steady on before I switched out the UI board, had proper voltage 13.5 to the UI board.
Any ideas?
Any ideas?
