jelias
- GDT580SMF8ES
- GE
- 6-10 years
Dishwasher has no water coming in at all.
I pulled the plug on the water valve and checked for voltage while in service mode. I only came up with 4VDC. Should I be checking this while in a normal cycle?
Followed flow chart in service manual and have 32ohms through the gray wire and the white with red stripe. While the Connector was unplugged I checked for 13.5 volts at the board and only had 4v.
from what I gathered it points to needing A new main board. Is their something I’m missing?
thank you
thank you
