- GDT635HMJ6ES
- GE
- 1-5 years
The top user interface stopped working with no lights, so I could not run any diagnostic.
I was able to to regain control but I had to cut the power to the washer 3 or 4 times and unplug /replug the UI control board to get access and the lights working again.
I could not find the service manual for my exact model GDT635HMJ6ES. so I used the one for GDT635HxM0xx but some of the diagnostic steps are not working,
so I suspect it's because I have the wrong manual. I would appreciate if someone can post the correct service Manual.
I would like to run more diagnostic while the UI pannel still works but I am not sure what caused the issue and what to test next....any suggestions would be appreciated
What I did so far:
1) The bottom Control board is square, I confirmed the input is 120V, and the green led lights is blinking very fast.
2) There is power to the UI control board since the lights are on, but not sure which PIN I need to check if the voltage is ok
3) I was able to get into consumer error mode by pressing the Cycle Select and Start buttons simultaneously for 5 seconds. the lock amber light remained ON.
4) I was able to enter service mode by pressing Cycle select for 5 seconds and tested each of the 6 load modes. some of them like the water valve test and Dry Fan test made no noise so I don't know if they are working for my specific model
5) I tried to enter self diagnostic mode for the control board by pressing CYCLE SELECT and DELAY but nothing happens, perhaps because I have the wrong service manual
6) I tried a small load cycle and it seems to work so far
What I did so far:
