GE dishwasher GDT655SMJ0ES not working
Jfive
Thomasville, GA
GDT655SMJ0ES
I have been having issues with my GE GDT655SMJ0ES dishwasher since August. In August I had a blank user interface and replaced it. It work for a while then the washer was telling door was not closed so I replaced the door latch and it did not fix it. So i replaced the control board and it worked for a while then the user interface went out again. I got it to work for a few months by turning the breaker on and off until came on. That quit working a few weeks ago.
I had a solid service light so i called the people i got the user board from and asked for a replacement but the guy insisted it was the control board instead so I agreed. Once installed the user lights came on and acted normal but it will not start. I get beeping and blinking as if the door was not closed. I also have a 2 times blinking service light which means unit is delay start which makes no sense.
The delay is not turned on. I tried multiple resets and breaker flips but everything remains the same. Any help would be appreciated.
Where are you getting your parts from?
The problem now is the machine control board is defective.
--->Here's the machine control board for your model: WD21X24901 Machine Control
Jfive
Thomasville, GA
I had no lights on user board before then I just installed the replacement control board and everything's working on user board but it will not start because it thinks the door is not closed. I had no issues with that before.
