Yes, when the dishwasher does random waking up/beeping/or trying start issues on its own occurs, the problem is your UI Board.
Here's the UI(user interface) Board for your model you can order:
WD21X23462 Kit Svc Ui Top Logic
"NOTE--->When replacing UI control boards, the new UI Board MUST be configured as per the instructions included with the replacement. If the personality is not set by using the 4 jumpers, the buttons, LED’s or cycles will not function properly"
Here's a couple other members that happened too, and the new UI Board fixed it:
Hey Jake I've got a random wake up occurring on my GE GDT655 dishwasher. Can you straighten me out on the personality jumper settings? you quoted above "NOTE--->When replacing UI control boards, the new UI Board MUST be configured as per the instructions included with the replacement. If the...
www.applianceblog.com
Hello, I recently repaired our GE GDT655SMJ2ES. It had been beeping rather often, like the door had been opened, but no one was near it. After some research (on other sites unfortunately) I believed the electronic control board was the culprit (part number WD21X24901). I purchased it, replaced...
Here's the service manual instructions for your exact model:
You will need to remove the whole door, then separate the door, then remove the front control console, to replace the UI Board.
Here's the service manual for your model:
https://drive.google.com/open?id=1M-G9W3HiaYnihdB5Cy-jfSPoVf8DZ7j7
Page 28 Door Removal
Page 30 Separate Door
Page 31 Front Control Console Removal
Page 32 UI Removal
Let us know how it goes after you replace the UI Board.
