pressu
- GDT655SSJ0SS
- GE
- 1-5 years
Hello,
I have GDT655SSJ0SS GE dishwasher. Initially it was not starting. I followed some reset options and started the unit just fine. Somehow the dishwasher spray arm came off and the edges of the arm got burnt and water started leaking from below.
I replaced the spray arm with a new one and cleaned little bit of water left under the filter area.
When started back with new spray arm, the unit is still leaking under the sump pump. I pulled out the dishwasher and checked if it is a hole or leak from the diverter assembly as noted in the thread below. But that doesn't seem to be the issue.
www.applianceblog.com
The leak seems to be coming from under the sump pump but not from the diverter assembly. I tried pouring in a glass of water into the unit and I can see water leaking from the white part shown in the picture below. You can see water dripping in one of the pics.
Can someone guide on what could be causing this issue? Is there a seal issue? could it still be diverter assembly?
FIXED - GDT655SSJ0SS GE Dishwasher Leaking underneath
I own a GE Dishwasher Model GDT655SSJ0SS. The other day when running I noticed that the unit was making an odd noise when running which I attributed to some of the dishes being packed too close and clanging together. The next day I noticed that the full soap packet was not used and the dishes...
