Ok Rod,
If the control board STATUS LED is STEADY ON--->UI personality not set, communications lost between UI and MC. You will need a
multimeter to check for 13.5 Volts DC.
The UI operational voltage is output from the main control board on connector J722 pin 2 black/green to pin 5 yellow/blue. If 13.5 Volts DC is found here, then the UI Board is the problem.
Here's the UI(user interface) Board for your model:
WD21X23462 Kit Svc Ui Top Logic
Connector J722 is located on the metal casing side of the main control board.
It's the one on the left above the ethernet port.
