sgopalan2012
- GDT665SSN2SS
- GE
- 1-5 years
Model: GDT665SSN2SS
Serial: GR719030B
3 months ago, I posted that my dishwasher was stopping mid-cycle (Post: https://www.applianceblog.com/mainf...dt665ssn2ss-stops-midcycle.92612/#post-478922). Based on Jake's suggestion (Thanks Jake!), I cleaned out the pressure sensor and the dishwasher started working again. We've used the dishwasher daily for the last 3 months without any issues.
Last week, the dishwasher stopped mid-cycle again. The symptoms are:
* I start it on Light mode, which should run for 51 minutes
* When the timer shows 25 minutes left, it tries to pump out the water and doesn't move on even when it's dry
* After a minute of doing this, the dishwasher resets
Things I've tried:
* In service mode, I confirmed the water fills up (mode 2), circulation works (mode 3) and the drain (mode 1) also seems to work.
* I cleaned out the pressure sensor but that didn't help
* I purchased a new pressure sensor (https://click.linksynergy.com/deepl...pressure-sensor-asm-wd21x25468-ap6976524.html) and installed it
Even with the new pressure sensor, the dishwasher stops mid-cycle. Any suggestions on what to try next?
Serial: GR719030B
Things I've tried:
