GE Dishwasher GDT695SMJ0ES will not run
Musigala
Jackson TN
GDT695SMJ0ES
This dishwasher was installed four years ago. This morning I tried to run it. It started beeping as though the door was not closed properly. We checked that nothing was preventing it from sealing. We cut the circuit breaker to the dishwasher. It still will not start.
--->Check your main control board STATUS LED, Tell us how many times its flashing in a row, or if its STEADY ON or STEADY OFF.
--->Here's the main control board for your model: WD21X24901 Machine Control
Restore Power, then make sure the door harness connector is attached to the bottom of the control board casing connector when you view the STATUS LED light, Also make sure the 120 volt connector to it in the front is still attached to it also.
Musigala
Jackson TN
Hey Jake,
So we cut the power via the circuit breaker again. This time we left it without power for about 90 minutes. It seems to be working again. I appreciate your help.
Ok, sounds good, if it keeps acting up let us know.
