GE Dishwasher Model GDP645SYN3FS Amber Cycle Status Indicator Light Has Stopped coming on
bearclawknight
United States
GDP645SYN3FS
Less than 1 year
New GE Dishwasher. Worked as indicated when first installed about a month ago. When starting a cycle, the exterior Cycle Status indicator light was amber, and then changed to white when cycle was done. Now, the amber light does not come on. The cycle works, the dishwasher still runs, and the white light appears when the cycle is done. Any ideas about cause and solution?
Sounds like a machine control board problem, GE dishwashers are notorious for machine control board problems, and UI(User Interface) problems.
Since its still under warranty contact GE at 1-800-432-2737 and they will send a tech. out to fix it for you for free.
Let us know what they find.
bearclawknight
United States
Will let you know what the tech finds in a couple of days. Not a good sign about the control board going out. But, it is an easy replacement process if it does need replacing. Thanks again for your response! Cheers.
Ok sounds good, thanks!
bearclawknight
United States
User interface malfunction. Part needs to be replaced. But, the part may not be available anywhere in the U.S. Did everyone get that? Parts for a brand new 2021 G.E. dishwasher are not available. Guess the supply chain hasn't recovered from the pandemic.
