GE dishwasher model PDT660SSF2SS error code E1
Nestor
Toronto, Ontario
PDT660SSF2SS
good evening ladies and gentszz
I’ve been working on an E1 error code with this GE model PDT660SSF2SS.
There was a huge puddle which is gone now. It used to also leave water standing in the tub.. I found a loose connection on the drain pump which is now fixed.
So far I’ve cleaned the return line& all filters.
Pulled the motor and found a piece of glass blocking the backdown valve along with some shards blocking the impeller on the drain pump.
tested a the motor with a resistance of 30ohms seems to be testing ok.
I decided to put everything back together…ran the service mode through and found upon completion it does t quite display 00/FO as required. It displays 01/FO.. any idea what’s going on here ?
