GE Dishwasher PDT825SSJ0SS No lights on control panel.
Bryson
MARYLAND
PDT825SSJ0SS
I called a repair electrician and he told me I had burnt fuse which was on the circuit board. I order a new circuit board and switched it myself. The board has a steady green light and still do not have an lights on my control panel. I have tried the select and start hold for 5 seconds and I get nothing.
All of this happened after a power outage.
Hi Bryson.
The problem is the UI Board.
Here's the UI Board for your model you can order:
It will come with instructions to set the UI personality jumpers per your model number. I replaced a UI Board a few weeks ago on a local customer's GE dishwasher and set the jumpers and it worked perfect!
Do you need the instructions to install it?
Bryson
MARYLAND
Thank you very much I will order the UI board. Yes can you please forward the instructions.
I'm attaching your tech manual below, it gives you the steps to replace it.
The steps listed in it:
Remove the Door, then Separate the Door, then Disassemble the Inner Door Components.
Once you release the 2 cables from the door hinges, the door pulls up and out.
Watch how he does it in this video:
Bryson
MARYLAND
I have changed the UI and still nothing. I don't have any lights and the Machine will not turn on. Could you please advise on what to do next?
Did you set the jumpers first before you installed the UI Board? You have to do that or it will not work.
The UI Board comes with instructions to set the jumpers per your model number.
Read post #4 here:
The box the new UI Board came in should of come with instructions, did you get the instructions?
If not, I'm attaching it below. Your Model is PDT825 so your personality is 2. Look on the 2nd page of the instructions and you will see how 2 is set per the jumpers.
