GE Dishwasher PDT825SSJ0SS Random Beeping
matdav
South Dakota
PDT825SSJ0SS
My PDT825SSJ0SS is randomly beeping. Everything else seems to be working correctly. I removed the control panel and the led is flashing once every 3 seconds. I can't find anything in the service manual addressing this issue. I have found other model #'s that talk about this issue and it seems like UI replacement is the most common repair.
Advice?
Yes, like I mentioned to Scott in this thread:
Its the UI Board you will need to order and replace.
This is the UI Board for your model you can order:
Make sure you set the personality jumpers(per the instructions that come with it) before you install the new UI Board.:)
I uploaded the service manual to your model here:
You can download it and it shows you how to remove the old UI Board and install the new UI Board.
